Removes a policy file ACL from the specified interface.
| policy_name | Specifies the ACL policy name. The name can be from 1-32 characters long. |
| port_list | Specifies the ingress or egress port list on which the ACL is applied. |
| vlan_name | Specifies the VLAN on which the ACL is applied. |
| ingress | Remove the ACL for packets entering the switch on this interface. |
| egress | Remove the ACL for packets leaving the switch from this interface |
The default direction is ingress.
This command removes ACLs that are contained in ACL policy files. To remove dynamic ACLs, use the following command:
configure access-list delete ruleName [ any | vlanvlan_name | portsport_list | all] {ingress | egress}
To remove all non-dynamic ACLs from all interfaces, do not specify any ports or VLANs.
The following command removes the ACL from port 1:2:
unconfigure access-list ports 1:2
The following command removes the ACLs from ports 1:2-6:3 and 7:1:
unconfigure access-list ports 1:2-6:3,7:1
The following command removes the wildcard ACL:
unconfigure access-list any
The following command removes all ACLs from all the interfaces, including the wildcard ACL:
The VLAN option was first available in ExtremeXOS 11.0.
The egress option was first available in ExtremeXOS 11.3.
The egress options are available on all platforms.
